Configure multicast stream limitation members on ports of the specified interface to configure the maximum number of streams on the interface.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
StreamLimit Members Field Descriptions
Use the data in the following table to use the StreamLimit Members tab.
Name |
Description |
IfIndex |
Displays the ID of the VLAN. |
Port |
Lists each slot and port number for this interface with stream limitation enabled. Identifies the
slot and port in one of the following formats:
MaxStreams |
Configures the maximum number of allowed streams for this specific port. The number of allowed streams cannot exceed the maximum number for the interface. The range is from 0–65535 and the default is 4. |
NumStreams |
Displays the current number of streams received on this interface. This value is a read-only value. |
